14 years ago
problems: object "std_logic" is not declared
Hi;
I try write a code for convert integer to ufixed:
package my_data_types is
type vector is array (natural range <>) of integer;
type ufixed is array (natural range <>) of std_logic;
end my_data_types;
library ieee;
library ieee_proposed;
use ieee_proposed.fixed_pkg.all;
use work.my_data_types.all;
entity fix is
port (clk: in bit;
nprev: in vector (0 to 7);
ip1: out ufixed (3 downto -4));
end fix;
architecture fix of fix is
signal n1: ufixed (3 downto -4);
begin
process(clk)
begin
if (clk'event and clk='1') then
for i in 0 to 7 loop
ip1(i) <= to_ufixed (nprev(i),n1);
end loop;
end if;
end process;
end fix;
I get this error:
Error (10482): VHDL error at fix.vhd(3): object "std_logic" is used but not declared.
How to declare the "std_logic" in package?..
    you clearly didnt for the package. you have to have separate library imports for each package and entity
    What do you mean by "separate library imports for each package and entity"?
    Thanks for reply
    in your code, you have the package above the library includes.
    you need to do this:
    --libraries for the package
    library ieee;
    use ieee.std_logic_1164.all;
    library IEEE_Porposed;
    use IEEE_Proposed.fixed_pkg.all;
    package my_package is
    end package;
    --Now the libraries for the entity
    library ieee;
    use work.my_package.all;
    Usually, you would put the package and entity in a separate file.
    May I suggest you read a VHDL tutorial - a lot of the questions you are asking are very very basic.
    Yes, I will. Since now, I still learn form vhdl tutorial and other materials for my better understand.Thanks for the advise =)
