14 years agoproblems: object "std_logic" is not declared
Hi;
I try write a code for convert integer to ufixed: package my_data_types is type vector is array (natural range <>) of integer; type ufixed is array (natural range <>) of std_logic; end my_data_types; library ieee; library ieee_proposed; use ieee_proposed.fixed_pkg.all; use work.my_data_types.all; entity fix is port (clk: in bit; nprev: in vector (0 to 7); ip1: out ufixed (3 downto -4)); end fix; architecture fix of fix is signal n1: ufixed (3 downto -4); begin process(clk) begin if (clk'event and clk='1') then for i in 0 to 7 loop ip1(i) <= to_ufixed (nprev(i),n1); end loop; end if; end process; end fix; I get this error: Error (10482): VHDL error at fix.vhd(3): object "std_logic" is used but not declared. How to declare the "std_logic" in package?..16 Replies
Yes, I will. Since now, I still learn form vhdl tutorial and other materials for my better understand.Thanks for the advise =)
May I suggest you read a VHDL tutorial - a lot of the questions you are asking are very very basic.
Thanks Tricky..I learn a lot from you. I appreciate it.
in your code, you have the package above the library includes.
you need to do this:
Usually, you would put the package and entity in a separate file.--libraries for the package library ieee; use ieee.std_logic_1164.all; library IEEE_Porposed; use IEEE_Proposed.fixed_pkg.all; package my_package is .... end package; --Now the libraries for the entity library ieee; use ieee.std_logic_1164.all; library IEEE_Porposed; use IEEE_Proposed.fixed_pkg.all; use work.my_package.all; - Altera_Forum
What do you mean by "separate library imports for each package and entity"?
Thanks for reply - Altera_Forum
you clearly didnt for the package. you have to have separate library imports for each package and entity
I already include the fixed_pkg..
you need to include the fixed_pkg.
This is my package code:
package my_data_types is type vector is array (natural range <>) of integer; type ufixed_array_t is array (natural range <>) of ufixed (3 downto -4); end my_data_types; But then, error said: Error (10482): VHDL error at fix.vhd(3): object "ufixed" is used but not declared How to avoid this error?..Thanks for reply - Altera_Forum
type ufixed_array_t is array(natural range <>) of ufixed(3 downto -4);
signal a : ufixed_array_t(0 to 7); etc
