sbj's avatar
sbj
2 months ago
SDM & Configuration Interface
  • Are there any SDM commands that allow uploading a bitstream, similar to the JTAG instruction 0x002 used for configuration?
  • Could you clarify the AVSTx8 (Avalon Streaming x8) programming interface protocol:
    • What is the data format and handshake mechanism?
    • Is it strictly limited to configuration use, or does it allow other use cases?
  • Is it possible to use the SDM pins (AVSTx8 interface) as a high-speed data path from an external host to the HPS?
    • For example, could it be used to transfer a U-Boot image to SPL after HPS boot?
