please explain use of set_output_delay
In thread : http://www.alteraforum.com/forum/showthread.php?t=1326 (http://www.alteraforum.com/forum/showthread.php?t=1326)
Brad wrote: " output delay max = board delay (max) - board clock skew (min) + tsu (external device) output delay min = board delay (min) - board clock skew (max) - th (external device) " Pease explain because I cannot see how this works. I think the reason I don't undertsand this is because I don't fully understand how it applies to set_output_delay i.e. from the Quartus manual (Table 7-4): Minimum tCO Requirement tCO Requirement set_output_delay -max <latch − launch − tCO requirement> why does <latch - launch> come in to it? Isn't "set_output_delay - max" equivalent to defining the tcomax? I feel that something needs to click. Regards, D.18 Replies
Brad,
No, I don't think so. I'm sure you know but Tco is clock to output delay. So, maximum Tco is simply the worst case clock to output delay for the sending end. i.e. from clock transition to data transition. I think the slowest and fastest regions are simply the data valid regions for the extremes of Tco. Regards, D - Altera_Forum
In gee's attachment, the Min_Tco arrow goes to the left side of the "Fastest" transition region, which is correct. (Min_Tco is how long old data remains valid before the pin starts changing for new data.)
The Max_Tco arrow goes to the left side of the "Slowest" transition region. Shouldn't it go to the right side? - Altera_Forum
Thanks gee,
yes this helps from the set_output_delay point of view. Many thanks, D. - Altera_Forum
I'll let someone else answer that. I think of set_output_delay and set_input_delay in the way I've described in my previous posts. tco and tsu are more intuitive to me, and I use documentation like Table 7-4 to do the conversion to set_output_delay and set_input_delay.
Thanks Brad, but having thought about it I think my question boils down to this simple one and I know I won't be happy unless I understand the answer:
for set_output_delay: does -max specify the most positive/least negative i.e. earliest time at which data can arrive wrt the clock ? does -min specify the least positive/most negative i.e. latest time at which data can arrive wrt the clock ? AND, does this convention also apply in exactly the same way to set_input_delay? Regards, D. - Altera_Forum
--- Quote Start --- output delay max = board delay (max) - board clock skew (min) + tsu (external device) ... tCO Requirement set_output_delay -max <latch − launch − tCO requirement> why does <latch - launch> come in to it? Isn't "set_output_delay - max" equivalent to defining the tcomax? --- Quote End --- For a common simple case, the source register driving out from the FPGA and the destination register receiving in the external device are using the same clock, and a single clock period is allowed (no multicycle). For that case, "latch - launch" is one clock period. set_output_delay -max is one clock period minus the FPGA's tco. If the board delays are ignored, then set_output_delay -max is also the same as the tsu of the external device--FPGA tco plus external device tsu equals one clock period. For set_output_delay -min in this simple case, "latch - launch" is zero. Table 7-4 in the Quartus handbook gives you the conversion between set_output_delay and tco/min tco in terms of latch and launch to cover more cases like where a PLL in the FPGA makes "latch - launch" be something different from a simple single clock period for max or zero for min. - Altera_Forum
Hang on, I think I may be getting it. Is this correct?
set_output_delay specifies the minimum and maximum data arrival times wrt the clock. so a maximum value is the value most ahead of the clock. +ve values before the clock and -ve values after the clock. This would explain my misunderstanding I think. I'd be grateful if someone could confirm this or put me right...
