18 years agoplease explain use of set_output_delay
In thread : http://www.alteraforum.com/forum/showthread.php?t=1326 (http://www.alteraforum.com/forum/showthread.php?t=1326) Brad wrote: " output delay max = board delay (max) - board clock ...
18 years ago --- Quote Start --- output delay max = board delay (max) - board clock skew (min) + tsu (external device) ... tCO Requirement set_output_delay -max <latch − launch − tCO requirement> why does <latch - launch> come in to it? Isn't "set_output_delay - max" equivalent to defining the tcomax? --- Quote End --- For a common simple case, the source register driving out from the FPGA and the destination register receiving in the external device are using the same clock, and a single clock period is allowed (no multicycle). For that case, "latch - launch" is one clock period. set_output_delay -max is one clock period minus the FPGA's tco. If the board delays are ignored, then set_output_delay -max is also the same as the tsu of the external device--FPGA tco plus external device tsu equals one clock period. For set_output_delay -min in this simple case, "latch - launch" is zero. Table 7-4 in the Quartus handbook gives you the conversion between set_output_delay and tco/min tco in terms of latch and launch to cover more cases like where a PLL in the FPGA makes "latch - launch" be something different from a simple single clock period for max or zero for min.
