18 years agoplease explain use of set_output_delay
In thread : http://www.alteraforum.com/forum/showthread.php?t=1326 (http://www.alteraforum.com/forum/showthread.php?t=1326) Brad wrote: " output delay max = board delay (max) - board clock ...
18 years agoThanks Brad, but having thought about it I think my question boils down to this simple one and I know I won't be happy unless I understand the answer:
for set_output_delay: does -max specify the most positive/least negative i.e. earliest time at which data can arrive wrt the clock ? does -min specify the least positive/most negative i.e. latest time at which data can arrive wrt the clock ? AND, does this convention also apply in exactly the same way to set_input_delay? Regards, D.
