18 years agoplease explain use of set_output_delay
In thread : http://www.alteraforum.com/forum/showthread.php?t=1326 (http://www.alteraforum.com/forum/showthread.php?t=1326) Brad wrote: " output delay max = board delay (max) - board clock ...
18 years agoHang on, I think I may be getting it. Is this correct?
set_output_delay specifies the minimum and maximum data arrival times wrt the clock. so a maximum value is the value most ahead of the clock. +ve values before the clock and -ve values after the clock. This would explain my misunderstanding I think. I'd be grateful if someone could confirm this or put me right...
