multiple driver error during simulation
Hi
I am doing a project and am stuck in the synthesis part in Quartus. The code was successfully compiled using icarus verilog software.But while compiling the code in Quartus , I get some error messages. The code is as follows with its description: /* Whenever positive edge of switch occurs , I need to take the incoming 8 bits (serial inputs on a single pin) and after that I have to discard all the bits, until the next posedge of switch. These bits are coming from a parallel in serial out register. These bits are stored in a reg called c and i is an integer which keeps the count. */ module test(si,po,clk,switch,flag); input si,clk,switch; output reg [7:0] po; reg [7:0] c,d; output reg flag; reg count; //reg flag; integer j,i; initial i=0; initial flag=0; initial count=0; always@(posedge clk) begin if (flag==1) begin c[i]=si; i=i+1; if(i==8) begin //count<=1; //po<=c; po<=(c[7:4]*10)+c[3:0]; i=0; flag<=0; end end end always@(posedge switch) begin flag<=1; end endmodule The error messges are as follows: Error: Can't elaborate top-level user hierarchy Error (10029): Constant driver at test.v(16) Error (10028): Can't resolve multiple constant drivers for net "flag" at test.v(38) Could anyone help in rectifying the mistake?17 Replies
Your flag is driven in two processes. the second process sets it permanently to high...
You must have a clock input as fast as serial stream (at least) then you run a counter(integer 0 ~ 8) set at zero at MSB or LSB location then increment to 8 and reset zero.(vhdl clocked process) --detect edge of switch switch_d <= switch; if switch = '1' and switch_d = '0' then count <= 1; elsif count < 8 then count <= count + 1; end if; if count < 8 then output(count) <= input; end if; if count = 7 then valid <= '1'; else valid <= '0'; end if; - Altera_Forum
Hi Kaz
I have some doubts on your expalaination as follows: switch_d <= switch; if switch /= switch_d then count <= 1; else count <= count + 1; end if; 1)by this are you detecting positive edge of switch 2) output <= input(count); what does this do? - Altera_Forum
I just corrected the output assignment.
Yes I detect switch rising level, the count is set to 1 due to one clock latency. for safer design you may put this for edge detection: if switch = '1' and switch_d = '0' then instead - Altera_Forum
--- Quote Start ---
--- Quote End --- As per the specifications the first 8 inputs are to be taken at the positive edge of switch. So why do you set count =1 at +ve edge and increase it by 1 when there's no posedge of switch? 2) if count < 8 then output(count) <= input; end if; what is this used for?(vhdl clocked process) --detect edge of switch switch_d <= switch; if switch = '1' and switch_d = '0' then count <= 1; elsif count < 8 then count <= count + 1; end if; if count < 8 then output(count) <= input; end if; if count = 7 then valid <= '1'; else valid <= '0'; end if; - Altera_Forum
You are right, I am still playing with this code for demo only as I am not aware of your inputs behaviour.
remember you can only detect switch edge one clock period after it rises. I am not sure if switch will rise once only or many times. you can run count 0~7 instead of 0 ~ 8 then it will set back to 0 ready waiting for switch to go up again. if switch = '1' and switch_d = '0' then count <= 1; else count <= count + 1; -- 0~7 free running end if; output(count) <= input; ...etc. - Altera_Forum
--- Quote Start --- I am not sure if switch will rise once only or many times. ...etc. --- Quote End --- Yes switch is allowed transitions "if switch = '1' and switch_d = '0' then" If I am not wrong this is detecting the positive edge So my count needs to be increased only when there is a positive edge and inputs(serial 8 bits) need to be stored in a reg. Moreover, me being familiar with Verilog, not VHDL, the syntax output(count) <= input; is troubling me - Altera_Forum
if your 8 bits are serial then they can't all come at rising edge of switch but one after the other as per input clock edge otherwise you need to clearify this point. I know RS232 uses no clock. Instead you run a counter to read bits by guess in effect... is that your case as well? is your clock as fast as serial bit stream?
Do you mean one bit arrives per switch edge?
Well what I intend to do is that the serial bits are coming at every clock edge(global clock) . i use the switch mechanism to detect that my inputs are stable and I am ready to take the incoming 8 bits serially. So the value of count needs to be increased only when I am taking the inputs.
Hope this would clarify my specifications. - Altera_Forum
--- Quote Start --- Do you mean one bit arrives per switch edge? --- Quote End --- its per clock edge
