multiple clocks
Hi:
I have two clocks in my design ,one is 12MHz ,the other is 50MHz ,when I transform a one bit signal from 12MHz to 50MHz ,the RTL viewer shows a very large delay between two registers that belong to 12MHz and 50MHz .Is there any settings in Quartus could reduce the delay?? thanks7 Replies
The delay is probably the transport delay from register to register. It shouldnt be a problem.
What I am interested in is when I use the RTL viewer ,the registers using the same clock has no delay ,but when I use the different clocks there is a delay of 1.349ns ,and it is seen as a combinational logic (dict://key.0895dfe8db67f9409db285590d870edd/combinational%20logic) delay ,but it is just a wire .I don't know why .
thank you very much for your patience (dict://key.0895dfe8db67f9409db285590d870edd/patience) ! - Altera_Forum
I'm sorry, I don't understand what you are trying to achieve. There is always a delay between two registers. Why are you interested in the delay and what is the problem you are trying to solve?
When I saw the delay between the two registers belonging to the 12M and 50M clocks,I don't know why there is a delay .If the registers using the same clock ,there if no delay which is saw by RTL vierer .
This doesn't seem very long to me... especially since the proper clock domain crossing logic would add at least 2 cycles, which would be 40ns in the 12MHz -> 50MHz direction. What you you trying to do exactly?
the delay is 1.349ns
What do you mean by "very large delay"?
With the clock domain crossing logic that you need to place you'll have a few cycles of latency anyway.
