16 years agomultiple clocks
Hi: I have two clocks in my design ,one is 12MHz ,the other is 50MHz ,when I transform a one bit signal from 12MHz to 50MHz ,the RTL viewer shows a very large delay between two registers that belo...
16 years agoWhat I am interested in is when I use the RTL viewer ,the registers using the same clock has no delay ,but when I use the different clocks there is a delay of 1.349ns ,and it is seen as a combinational logic (dict://key.0895dfe8db67f9409db285590d870edd/combinational%20logic) delay ,but it is just a wire .I don't know why .
thank you very much for your patience (dict://key.0895dfe8db67f9409db285590d870edd/patience) !
