16 years agomultiple clocks
Hi: I have two clocks in my design ,one is 12MHz ,the other is 50MHz ,when I transform a one bit signal from 12MHz to 50MHz ,the RTL viewer shows a very large delay between two registers that belo...
16 years agoThis doesn't seem very long to me... especially since the proper clock domain crossing logic would add at least 2 cycles, which would be 40ns in the 12MHz -> 50MHz direction. What you you trying to do exactly?
