16 years agomultiple clocks
Hi: I have two clocks in my design ,one is 12MHz ,the other is 50MHz ,when I transform a one bit signal from 12MHz to 50MHz ,the RTL viewer shows a very large delay between two registers that belo...
16 years agoWhen I saw the delay between the two registers belonging to the 12M and 50M clocks,I don't know why there is a delay .If the registers using the same clock ,there if no delay which is saw by RTL vierer .
