16 years agoModelSim does not show FIFO's signals
I got a NIOS-II system with a custom avalon interface. This custom block extantiate a FIFO, which was created using the Megawizard tool. When I run ModelSim everything seems to be working but all the FIFO's signal are undefined. ModelSim does not generate any errors or warning. The testbench does not have reference of the FIFO. I'm running Quartus 8.1. Thanks Horacio11 Replies
Hello horacioEsta,
>># ** Warning: (vsim-3473) Component instance "fifo1 : fifo512x32" is not bound.>> This means that the FIFO instance from the Quartus library is not available for the simulation environment. Thats the reason why you see the signal are undefined. Please create a simulation library in Modelsim and copy the models from Quartus and the start the simulation. You will see the required signals at the output. To see how to make library please refer the Modelsim userguide, its pretty simple. All the best. rsenthil78 - Altera_Forum
Hello horacioEsta,
Yes that is right, I get the following message:
# ** Warning: (vsim-3473) Component instance "fifo1 : fifo512x32" is not bound. What do I do about it? - Altera_Forum
do you get any other warning messages from Modelsim? If not please check if you have the quartus library in Modelsim. In this case when you try to compile you may get warning message.
Here is how I generate the reset for this core:
INT_RESET <= csi_reset or CONTROL_REG(31); In the simulation, I can see the core getting reset when I write to the control register (bit 31). On reset I see the simdata getting set to the right value. Here is the FIFO: -------------------------------------------------------------- COMPONENT FIFO512X32 IS PORT ( aclr : IN STD_LOGIC ; clock : IN STD_LOGIC ; data : IN STD_LOGIC_VECTOR (31 DOWNTO 0); rdreq : IN STD_LOGIC ; wrreq : IN STD_LOGIC ; empty : OUT STD_LOGIC ; full : OUT STD_LOGIC ; q : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); usedw : OUT STD_LOGIC_VECTOR (8 DOWNTO 0) ); END COMPONENT; ------------------------------------------------------------- And here is how I got it connected: ------------------------- FIFO1: FIFO512X32 PORT MAP( aclr => INT_RESET, clock => csi_clk, data => SIM_DATA, rdreq => FIFO_RD, wrreq => FIFO_WE, empty => STATUS_REG(9), full => STATUS_REG(10), q => FIFO_Q, usedw => STATUS_REG( 8 DOWNTO 0) ); ------------------------- I got some of the control lines going out to test points, just for monitor simulation purposes: coe_tstpt(0) <= FIFO_WE; coe_tstpt(1) <= FIFO_RD; coe_tstpt(2) <= STATUS_REG(9); coe_tstpt(3) <= STATUS_REG(10); I can see that the STATUS bits 0 to 10 are undefined. Everything else is drive. As I stated before, the FIFO model is not listed in the Testbench. This testbech was created by the SOPC Builder. Do I need to modify it to have the FIFO model in the testbench. How come ModelSim does not complain about it? Thanks - Altera_Forum
--- Quote Start --- The inputs are the control lines, rdreq, wrreq, and the data. These are all zero in the design. ModelSim shows that. The FIFO is instanciated in the design. I don't see an entry in the testbech for the FIFO. I can't call myself a Modelsim expert. --- Quote End --- Hi, that means the inputs of th Fifo are defined :confused: Do the Fifo have a reset input ? Kind regards GPK - Altera_Forum
The FIFO is instanciated in the design. I don't see an entry in the testbech for the FIFO. I can't call myself a Modelsim expert. - Altera_Forum
--- Quote Start --- That is right, all input and output signals of this FIFO are undefined. When I run the simulation, I only get "XXXXX", when I attempt to read the FIFO's status bits ( Empty flag, Full flag, wordsin). Any ideas? --- Quote End --- Hi, where is the instanciated ? In your design or in the testbench ? Kind regards GPK - Altera_Forum
Tipically the some/all of the output signals are only defined if all input signals are defined (!= X).
So please fix your testbench so that it provides valid inputs to the FIFO. After that the outputs of the FIFO should be valid (!= X) - Altera_Forum
