16 years agoModelSim does not show FIFO's signals
Hello, I got a NIOS-II system with a custom avalon interface. This custom block extantiate a FIFO, which was created using the Megawizard tool. When I run ModelSim everything seems to be worki...
16 years ago --- Quote Start --- The inputs are the control lines, rdreq, wrreq, and the data. These are all zero in the design. ModelSim shows that. The FIFO is instanciated in the design. I don't see an entry in the testbech for the FIFO. I can't call myself a Modelsim expert. --- Quote End --- Hi, that means the inputs of th Fifo are defined :confused: Do the Fifo have a reset input ? Kind regards GPK
