16 years agoModelSim does not show FIFO's signals
Hello, I got a NIOS-II system with a custom avalon interface. This custom block extantiate a FIFO, which was created using the Megawizard tool. When I run ModelSim everything seems to be worki...
16 years agodo you get any other warning messages from Modelsim? If not please check if you have the quartus library in Modelsim. In this case when you try to compile you may get warning message.
