Ouseph7's avatar
Ouseph7
1 month ago
Licence in Altera 2 Complete Design Suite version 13.0 SP1 For cyclone 1
"I am using Quartus II 13.0 Subscription Edition to compile code for a Cyclone I device (EP1C3T100C8). While the build compiles successfully, the software does not generate the .sof file needed to create a .jic file. Since this device family might have limited support, does anyone know how to enable or generate the .sof file in this version?"
  • Hi Ouseph7
    As mentioned by FvM, Quartus II 13.0 Subscription Edition requires a valid Quartus II Subscription Edition license.
    Based on the device support information (https://www.altera.com/design/guidance/software/device-support), Cyclone® I devices are supported only in specific Quartus software editions and versions.
    You may consider one of the following options:
    1. Use Quartus II Web Edition 11.0 SP1, as suggested by FvM and jAlter. This version supports Cyclone I devices and does not require a paid subscription license.
    2. Purchase a Quartus II Subscription Edition license if you need to continue using Quartus II 13.0 Subscription Edition.
    Please review these options and select the one that best suits your requirements. If you have any questions, feel free to let us know. We will be happy to assist further.
    Besides, thank you to FvM  and jAlter too for sharing valuable insights and recommendations.
    ZiYingE_Altera
    • ZiYingE_Altera's avatar
      ZiYingE_Altera
      Hi Ouseph7,
      Just checking in to see if you have any updates or further questions?
      Please feel free to let me know if I can help with anything else.
      ZiYingE_Altera
  • jAlter's avatar
    jAlter
    Since a few months already Altera is making legacy versions available. Quartus 11-0 SP1 is here:
    https://www.altera.com/downloads/fpga-development-tools/quartus-ii-web-edition-design-software-version-11-0-b123-windows
    • FvM's avatar
      FvM
      Hi jAlter,
      you are right, I forgot about the new Legacy Download Center. Thanks for correcting me.
      Regards Frank
  • Ouseph7's avatar
    Ouseph7
    Hi FvM​ ,
    Warning (292011): Can't generate programming files because you are currently using the Quartus II software in Evaluation Mode
    this is the warning generated on compiling. if subscribtion is needed can you guide me how to take subscription..?
      ZiYingE_Altera
      Hi Ouseph7,
      Good day!
      As we have not heard back from you, I will set this case to close. If you still need further assistance, you are welcome ​response this case, someone will be right with you.
      ZiYingE_Altera
  • FvM's avatar
    FvM
    Cyclone .sof generation works for me with 13.0.1 SP1 Full Version (Build 232 06/12/2013). Tested with EP1C12Q240.
    You should see an error message indicating why no .sof is generated. What is it?
    Frank
  • Hi Ouseph,
    Thank you for reaching out. I am currently looking into this issue. I will get back to you once I have more information.
    ZiYingE_Altera
