Ouseph7
1 month agoLicence in Altera 2 Complete Design Suite version 13.0 SP1 For cyclone 1
"I am using Quartus II 13.0 Subscription Edition to compile code for a Cyclone I device (EP1C3T100C8). While the build compiles successfully, the software does not generate the .sof file needed to cr...
Ouseph7
1 month agoHi FvM ,
Warning (292011): Can't generate programming files because you are currently using the Quartus II software in Evaluation Mode
this is the warning generated on compiling. if subscribtion is needed can you guide me how to take subscription..?
- ZiYingE_Altera1 month ago
Contributor
Hi Ouseph7,
Good day!
As we have not heard back from you, I will set this case to close. If you still need further assistance, you are welcome response this case, someone will be right with you.
ZiYingE_Altera
