9 years agoJTAG timing constraints
Over the years my company has made many Altera FPGA designs, and for a long time the way-of-work for JTAG constraints remained undefined and of little consequence. Then for a couple Arria V designs, JTAG instability became a hot issue (e.g. random failures when discovering the JTAG chain, using SignalTap, using SystemConsole). Our initial strategy probably was to not constrain JTAG at all (as JTAG is 'slow' and its logic is fixed), but then we would get Quartus errors regarding unconstrained ports/clocks. We then tried to find constraints recommended directly by Altera, but never could find a conclusive, complete, satisfactory answer. Based on experience we do feel that the constraints actually affect JTAG stability, and so we're still keeping an eye out for a good solution. Note that the JTAG hardware part for our designs was always rather basic, so we don't think the instability originates from there. A selection of the examples and best practices we have found and tried over the years: - Old TimeQuest cookbook: can't find it anymore - Recent TimeQuest cookbook: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/mnl_timequest_cookbook.pdf - Knowledge base item 1: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd07182016_788.html - Knowledge base item 2: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd04282008_867.html - Forum post: https://www.alteraforum.com/forum/showthread.php?t=56328 Some of these examples seem to contradict each other, adding to the confusion. My specific questions for Altera are: 1) What are the JTAG constraints recommended by Altera? 2) Are there any plans regarding JTAG constraints? E.g. having Quartus automatically implement them? 3) Are there any known JTAG issues for the Arria V family? If there are, are these fixed in the 10 series? Best regards, Daniel17 Replies
Figured out better way sending picture... Insert it, rather than attach it :-)
Hopefully this is better.. https://www.alteraforum.com/forum/attachment.php?attachmentid=14533 - Altera_Forum
--- Quote Start --- "Error 16328: Put the device in User mode …" Thanks, --- Quote End --- This error is because CRC mismatch. 1.Try to DISABLE it and program. Check session 3.6.2 https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-10/ug_m10_config.pdf or try to program using both the methods (By using on-chip ram / by using on-chip flash) https://www.youtube.com/watch?v=0k4azmdw9sk Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Could there be any Voltage regulation issue? I am using LM1117 chips for 2.5V and 3.3V supplies.
Part nos are LM1117MPX-3.3/NOPB and LM1117MPX-2.5/NOPB Scope is showing values between 3.36 - 3.40 and 2.56 – 2.60V. So there is about 4mV swing / ripple on each of the supply. Thank you, - Altera_Forum
Hello Anand,
On my second board, I tried the SOF first and it programmed without any issue, on the first attempt itself. On trying the POF file, I got the following message.. Info (209060): Started Programmer operation at Wed Dec 06 17:04:27 2017 Info (209017): Device 1 contains JTAG ID code 0x031820DD Info (209044): Erasing MAX 10 configuration device(s) Info (209023): Programming device(s) Info (209021): Performing verification on device(s) Error (209048): Verify failure on device number 1 Error (209012): operation failed (83% on the 'Progress' bar) Info (209061): Ended Programmer operation at Wed Dec 06 17:07:13 2017 On trying again, I get following message right away, as before... Info (209061): Ended Programmer operation at Wed Dec 06 17:07:13 2017 Info (209060): Started Programmer operation at Wed Dec 06 17:07:51 2017 Info (209017): Device 1 contains JTAG ID code 0x031820DD Info (209044): Erasing MAX 10 configuration device(s) Warning (16328): The real-time ISP option for Max 10 is selected. Ensure all Max 10 devices being programmed are in user mode when requesting this programming option Error (209012): operation failed - Altera_Forum
Hello Anand,
Thanks for trying to help. 1. JTAGEN on both boards is pulled up (10K to 3.3V) 2. All three pins pulled up to 2.5V using 10K Res. (They are on bank 8, where the VCCIO is 2.5V I referred sec 1.1.2 of the Max 10 'Pin connection guidelines' document) 3. TDI and TMS also pulled up by 10K but to 2.5V, as per the same sec 1.1.2 of the 'Pin connection guidelines' document. (I did not use diodes / caps on the JTAG lines (on either of the documents) to prevent 'voltage overshoot' problem, since as per the documents it is recommended, when JTAG supply is over 2.5V) 4. CONF_DONE also stays low, along with nStatus. Only nConfig goes high, which is expected. 5. I followed 'Pin connection guidelines', the 'Max 10 Design Guidelines' and the 'Board Design Guidelines AN114' documents, for both the boards. 6a) I just tried loading the 'sof' file and it got loaded on the very first attempt! Here's the message I get.. "info (209060): started programmer operation at wed dec 06 09:34:30 2017info (209016): configuring device index 1
info (209017): device 1 contains jtag id code 0x031820dd
info (209007): configuration succeeded -- 1 device(s) configured
info (209011): successfully performed operation(s)
info (209061): ended programmer operation at wed dec 06 09:34:31 2017" 6b) However I really need to load the POF file and this is the message I am still getting... lo and behold.. I got it configured the first time using the POF file!! I am using the 'exact same' setup I used yesterday evening before leaving work. Did not even move a wire, except for plugging the power connector back on! I only started with the SOF file today (which I never tried on this newer board), before the POF file. So there's something really erratic / intermittent, which is bad as these boards are for commercial use!! This is very similar to the comments posted at the start of this post, that JTAG configuration reliability is becoming erratic :-| ! The person ([email protected]) stated.. “jtag instability became a hot issue (e.g. random failures when discovering the jtag chain, using signaltap, using systemconsole).” For the past two days, when using the POF file, I would only read the Device ID and then get error message something like "Error 16328: Put the device in User mode …" Unfortunately I had to clear my browser cache and don't recall the exact message. If it re-appears I would post it. Thanks,
Hello Anand,
info (209061): ended programmer operation at wed dec 06 09:34:31 2017" 6b) However I really need to load the POF file and this is the message I am still getting... lo and behold.. I got it configured the first time using the POF file!! I am using the 'exact same' setup I used yesterday evening before leaving work. Did not even move a wire, except for plugging the power connector back on! I only started with the SOF file today (which I never tried on this newer board), before the POF file. So there's something really erratic / intermittent, which is bad as these boards are for commercial use!! This is very similar to the comments posted at the start of this post, that JTAG configuration reliability is becoming erratic :-| ! This person ([email protected]) stated.. “jtag instability became a hot issue (e.g. random failures when discovering the jtag chain, using signaltap, using systemconsole).” For the past two days, when using the POF file, I would only read the Device ID and then get error message something like "Error 16328: Put the device in User mode .." Unfortunately I had to clear my browser cache and don't recall the exact message. If it re-appears I would post it. Thanks,
OP (with the Arria V) reporting in.
--- Quote Start --- I wonder if there's been any further progress or a 'definite conclusion' on this matter? --- Quote End --- I made a separate support ticket for this issue; Altera's response can be summarized as follows:- Not the whole JTAG controller is hard IP, therefore timing constraints are vital.
- This is are the currently recommended constraints: https://www.altera.com/support/support-resources/knowledge-base/tools/2016/why-do-i-see-jtag-problems-when-using-the-signaltap-ii-logic-ana.html
- There are no known Arria V issues related to our issue.
Hi
1.Is JTAGEN pin of MAXa0 device handled same in both the boards? 2.Is nSTATUS CONF_DONE nCONFIG pulled up with 10K? 3.Is TDI and TMS pulled up? 4.What is the status on CONF_DONE pin when nSTATUS is low? 5.If you schematic followed all the guidelines. there should not be a problem and trace length difference will also not affect the signal properties at lower frequency so even that's fine(length difference can be 100mil to 200mil generally) 6.Do you get message during configuration can you attach screen short of it.(put it in word and attach as word file) Or Can you write simple program (control led using switch) and load the file and check.(To recheck the programming steps) Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
It seems the picture is loosing it's resolution, after attaching it.
Perhaps some limitations due to Forum's policies..?
