9 years agoJTAG timing constraints
Hi, Over the years my company has made many Altera FPGA designs, and for a long time the way-of-work for JTAG constraints remained undefined and of little consequence. Then for a couple Arria ...
8 years agoHello Anand,
On my second board, I tried the SOF first and it programmed without any issue, on the first attempt itself. On trying the POF file, I got the following message.. Info (209060): Started Programmer operation at Wed Dec 06 17:04:27 2017 Info (209017): Device 1 contains JTAG ID code 0x031820DD Info (209044): Erasing MAX 10 configuration device(s) Info (209023): Programming device(s) Info (209021): Performing verification on device(s) Error (209048): Verify failure on device number 1 Error (209012): operation failed (83% on the 'Progress' bar) Info (209061): Ended Programmer operation at Wed Dec 06 17:07:13 2017 On trying again, I get following message right away, as before... Info (209061): Ended Programmer operation at Wed Dec 06 17:07:13 2017 Info (209060): Started Programmer operation at Wed Dec 06 17:07:51 2017 Info (209017): Device 1 contains JTAG ID code 0x031820DD Info (209044): Erasing MAX 10 configuration device(s) Warning (16328): The real-time ISP option for Max 10 is selected. Ensure all Max 10 devices being programmed are in user mode when requesting this programming option Error (209012): operation failed
