image read in vhdl
i want to read an image (or preferably a matrix of size 8x8) pixel by pixel in one clock cycle(if rising edge then read one pixel in 2nd rising edge 2nd pixel)....thanks in advance
--- Quote Start --- Why bother declaring row_pixel at all? its just an array of length 1, why not just return an integer? Why are you using an inout for output? this is bad practice the error is here: for i in 0 to 3 loop ret_pixel(i) := row1(pixel, i); end loop; ret_pixel is a row_pixel type with a range 0 to 0. Your loop is going out of range. --- Quote End --- what should i write if i have to extract each value from the row (output) in each clock cycle.... - Altera_Forum
what about something simple like this?
signal row, col : unsigned(1 downto 0) := "00"; process(clk) begin if rising_edge(clk) begin output <= input(to_integer(row), to_integer(col)); col <= col + 1; if col = "11" then row <= row + 1; end if; end if; end if; - Altera_Forum
I want to follow this algorithm :
d(n)=output(2n+1)-(1/2)[output(2n)+output(2n+2)] where output is an array consisting of 64 values... after each clock cycle d(n) gets a definite value based on calculation so according to this algorithm d(n) must contain 31 values... ---main code package newtype is type row_t is array(0 to 63) of integer; type approx_t is array(0 to 30) of integer; type matrix_t is array(0 to 7, 0 to 7) of integer; end newtype; library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; use work.newtype.all; entity test is port(input: in matrix_t; clk: in std_logic; output : inout row_t; d : out approx_t); end test; architecture arch of test is signal matrix : matrix_t; signal temp_row : integer; signal temp_approx : integer; signal i : unsigned(5 downto 0) := "000000"; signal n : unsigned(4 downto 0) := "00000"; signal count : unsigned(6 downto 0) := "0000000"; signal limit : unsigned (6 downto 0) := "1111111"; signal row, col : unsigned(2 downto 0) := "000"; begin process(clk) begin if rising_edge(clk) then temp_row <= input(to_integer(row), to_integer(col)); output(to_integer(i)) <=temp_row; col <= col + 1; if col = "111" then row <= row + 1; end if; i<=i+1; count <= count + 1; -----here i am trying to waste some clock cycles, because after few clock cycles only required number of outputs will be available for operation. if count >= limit then temp_approx <= output(2*((to_integer(n)))+1)-0.5*(output(2*((to_integer(n))))+output(2*((to_integer(n)))+2));--error: Found 0 definitions for operator "*" d(to_integer(n)) <= temp_approx; n<= n+1; end if; end if; end process; end arch; ---testbench library IEEE; use IEEE.Std_logic_1164.all; use ieee.std_logic_unsigned.all; use IEEE.Numeric_Std.all; use work.newtype.all; entity test_tb is end; architecture bench of test_tb is component test port(input: in matrix_t; clk: in std_logic; output : inout row_t; d : out approx_t); end component; signal input: matrix_t; signal clk: std_logic; signal output: row_t; signal d: approx_t; constant clock_period: time := 0.1ns; signal stop_the_clock: boolean; begin uut: test port map ( input => input, clk => clk , output => output); stimulus: process begin input <= ((0,1,2,9,10,5,8,4), (3,5,6,10,2,9,10,5), (9,8,11,2,10,2,9,10), (9,7,1,6,10,2,9,10),(1,4,5,3,6,10,8,9),(14,2,3,5,6,7,8,9),(9,7,1,6,10,2,9,10),(12,4,7,8,9,2,12,0)); wait for 50ns; stop_the_clock <= true; wait; end process; clocking: process begin while not stop_the_clock loop clk <= '1', '0' after clock_period /2; wait for clock_period; end loop; wait; end process; end; error is : Found 0 definitions for operator "*". please tell where is the mistake ?? Thanks in advance - Altera_Forum
you cannot multiply unsigned type and real type (0.5). Real type is not suitable for synthesis. Try /2 instead.
But I still think you have real issues with your architecture. It is very inefficient and written as if it was software. Why do you have to "waste" clock cycles? Also - what external interfaces are you using? I doubt there are enough pins to output an entire 8x8 array - so why not do the calcualtions serially? Have you drawn out your circuit on paper? - Altera_Forum
wasting clock cycles means the algorithm should start after some defined clock cycles
yes i have drawn circuit on paper... the thing is i am trying to do the project first on a small matrix of 8x8... if the algorithm works properly then i will implement with the complete 512x512 image - Altera_Forum
With a 512x512 image - you need to use ram. There will not be enough resources to store an entire image in registers (and it would take forever to compile).
You need to rethink your design. - Altera_Forum
--- Quote Start --- With a 512x512 image - you need to use ram. There will not be enough resources to store an entire image in registers (and it would take forever to compile). You need to rethink your design. --- Quote End --- I understand that sir completely... But currently i have to work with a small matrix only...once algorithm is developed it is not very difficult to apply it to a full size image.. (i have generated the hex file of the image from MATLAB, all i need is to load each value from that file with every clock cycle, hence i am trying to develop the code for algorithm first...) - Altera_Forum
yes temp_aprrox, output gets reasonable values .
and yes row and col are correct at the correct times. only problem is with "d".... - Altera_Forum
I think you have replied to the wrong forum - but do you realise that D will only take 1 value every 128 clocks, so it will take 8192 clocks to complete every value in the D array? Until they are set, D(r,c) will have the value -2^31.
I have changed the code like this:-
for 0 to 64 clocks output will be extracted and once clock pulses exceed 64 (i.e., count value exceeds 64) algorithm will start and values will be loaded into d. ---main code package newtype is type row_t is array(0 to 63) of integer; type matrix_t is array(0 to 7, 0 to 7) of integer; type approx_t is array(0 to 30) of integer; end newtype; library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use work.newtype.all; entity test is port(input: in matrix_t; clk: in std_logic; output : inout row_t ; d : out approx_t); end test; architecture arch of test is signal matrix : matrix_t; signal temp_row : integer; signal i : unsigned(5 downto 0) := "000000"; signal row, col : unsigned(2 downto 0) := "000"; signal count : integer := 0; signal limit : integer := 64; signal n : unsigned(6 downto 0) := "0000000"; signal temp_approx : integer; begin process(clk) begin if rising_edge(clk) then if count < limit then temp_row <= input(to_integer(row), to_integer(col)); output(to_integer(i)) <=temp_row; col <= col + 1; if col = "111" then row <= row + 1; end if; i<=i+1; else temp_approx <= output(2*((to_integer(n)))+2)-(1/2)*(output(2*((to_integer(n)))+1)+output(2*((to_integer(n)))+3)) ; d(to_integer(n)) <= temp_approx; n<= n+1 ; end if; count <= count + 1; end if; end process; end arch; but still d contains garbage
