10 years agoimage read in vhdl
i want to read an image (or preferably a matrix of size 8x8) pixel by pixel in one clock cycle(if rising edge then read one pixel in 2nd rising edge 2nd pixel)....thanks in advance
10 years agoI have changed the code like this:-
for 0 to 64 clocks output will be extracted and once clock pulses exceed 64 (i.e., count value exceeds 64) algorithm will start and values will be loaded into d. ---main code package newtype is type row_t is array(0 to 63) of integer; type matrix_t is array(0 to 7, 0 to 7) of integer; type approx_t is array(0 to 30) of integer; end newtype; library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use work.newtype.all; entity test is port(input: in matrix_t; clk: in std_logic; output : inout row_t ; d : out approx_t); end test; architecture arch of test is signal matrix : matrix_t; signal temp_row : integer; signal i : unsigned(5 downto 0) := "000000"; signal row, col : unsigned(2 downto 0) := "000"; signal count : integer := 0; signal limit : integer := 64; signal n : unsigned(6 downto 0) := "0000000"; signal temp_approx : integer; begin process(clk) begin if rising_edge(clk) then if count < limit then temp_row <= input(to_integer(row), to_integer(col)); output(to_integer(i)) <=temp_row; col <= col + 1; if col = "111" then row <= row + 1; end if; i<=i+1; else temp_approx <= output(2*((to_integer(n)))+2)-(1/2)*(output(2*((to_integer(n)))+1)+output(2*((to_integer(n)))+3)) ; d(to_integer(n)) <= temp_approx; n<= n+1 ; end if; count <= count + 1; end if; end process; end arch; but still d contains garbage
