10 years agoimage read in vhdl
i want to read an image (or preferably a matrix of size 8x8) pixel by pixel in one clock cycle(if rising edge then read one pixel in 2nd rising edge 2nd pixel)....thanks in advance
10 years agoI want to follow this algorithm :
d(n)=output(2n+1)-(1/2)[output(2n)+output(2n+2)] where output is an array consisting of 64 values... after each clock cycle d(n) gets a definite value based on calculation so according to this algorithm d(n) must contain 31 values... ---main code package newtype is type row_t is array(0 to 63) of integer; type approx_t is array(0 to 30) of integer; type matrix_t is array(0 to 7, 0 to 7) of integer; end newtype; library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; use work.newtype.all; entity test is port(input: in matrix_t; clk: in std_logic; output : inout row_t; d : out approx_t); end test; architecture arch of test is signal matrix : matrix_t; signal temp_row : integer; signal temp_approx : integer; signal i : unsigned(5 downto 0) := "000000"; signal n : unsigned(4 downto 0) := "00000"; signal count : unsigned(6 downto 0) := "0000000"; signal limit : unsigned (6 downto 0) := "1111111"; signal row, col : unsigned(2 downto 0) := "000"; begin process(clk) begin if rising_edge(clk) then temp_row <= input(to_integer(row), to_integer(col)); output(to_integer(i)) <=temp_row; col <= col + 1; if col = "111" then row <= row + 1; end if; i<=i+1; count <= count + 1; -----here i am trying to waste some clock cycles, because after few clock cycles only required number of outputs will be available for operation. if count >= limit then temp_approx <= output(2*((to_integer(n)))+1)-0.5*(output(2*((to_integer(n))))+output(2*((to_integer(n)))+2));--error: Found 0 definitions for operator "*" d(to_integer(n)) <= temp_approx; n<= n+1; end if; end if; end process; end arch; ---testbench library IEEE; use IEEE.Std_logic_1164.all; use ieee.std_logic_unsigned.all; use IEEE.Numeric_Std.all; use work.newtype.all; entity test_tb is end; architecture bench of test_tb is component test port(input: in matrix_t; clk: in std_logic; output : inout row_t; d : out approx_t); end component; signal input: matrix_t; signal clk: std_logic; signal output: row_t; signal d: approx_t; constant clock_period: time := 0.1ns; signal stop_the_clock: boolean; begin uut: test port map ( input => input, clk => clk , output => output); stimulus: process begin input <= ((0,1,2,9,10,5,8,4), (3,5,6,10,2,9,10,5), (9,8,11,2,10,2,9,10), (9,7,1,6,10,2,9,10),(1,4,5,3,6,10,8,9),(14,2,3,5,6,7,8,9),(9,7,1,6,10,2,9,10),(12,4,7,8,9,2,12,0)); wait for 50ns; stop_the_clock <= true; wait; end process; clocking: process begin while not stop_the_clock loop clk <= '1', '0' after clock_period /2; wait for clock_period; end loop; wait; end process; end; error is : Found 0 definitions for operator "*". please tell where is the mistake ?? Thanks in advance
