15 years ago
How to align an output clock mux to 2 inputs clocks
I'm in charge of prototyping an ASIC into an FPGA altera Stratix3sl200.
My problem is coming from the usage of clocks muxes inside ASIC :mad:
Basically, they use a simple 2 inputs (clk1 and clk2) / 1 output (clk_switch) classic mux with 1 selection signal (sel_clk) to mux 2 clocks signals.
The need is that the resulting output clock clk_switch must be aligned either with the clk1 when sel_clk is 0 and with clk2 when sel_clk is 1.
It seems to be very easy onto ASIC :( but in a FPGA :confused:
Is there a way to constraints Quartus to do such things ? (by adding good delay before the GLOBAL for instance ...)
How ? Using Sdc ? What i need to constraints/declare ?
A little quartus example is really welcome ... if possible.
My project is onto Quartus 9.1 sp1 with timequest.
Note that CLK1, CLK2 and CLK_SWITCH need to be on FPGA clocks trees too (there is a large amount of FFs usings theses 3 clocks).
Thanks a lot.
Regards.
    I've made a small example which might fulfill your req's,
    the idea is that your internally generated clocks (e.g 100MHz & 66Mhz) are replaced
    with clocks generated by a pll, 100 & 66 MHz,
    both pll outputs also go to clk_mux - altera megawizard ALTCLKCTRL module,
    which works as the clock mux,
    and both pll outputs go to "stratixiii_clkena" clock buff to compensate multiplexing
    delay [in case quartus is not smart enough to insert the buffs itself];
    in the example cnt_100, cnt_66 mimics modules working with 100 and 66 clocks,
    cnt_sw works with 'switchable' clock;
    module clk_switch
    (  input            ext_clk,  switch,
       output reg  cnt_100, cnt_66, cnt_sw
    wire c100, c66;
    wire sys_clk100, sys_clk66, sys_clk_sw;
     pll pll_i
           ( .inclk0(ext_clk), .c0(c100), .c1(c66) );
     stratixiii_clkena buff100
      ( .ena(1'b1), .enaout(),
        .inclk(c100), .outclk(sys_clk100) );
     stratixiii_clkena buff66
        .inclk(c66), .outclk(sys_clk66) );
     clk_mux clock_mux
        ( .clkselect(switch), .inclk0x(c100), .inclk1x(c66),
          .outclk(sys_clk_sw) );
     always @(posedge sys_clk100)
       cnt_100 <= cnt_100 + 1'b1;
     always @(posedge sys_clk66)
       cnt_66 <= cnt_66 + 1'b1;
     always @(posedge sys_clk_sw)
       cnt_sw <= cnt_sw + 1'b1;
    endmodule
    have fun j_andr
    I struggle with that since 10 years :)
    So, you confirm that there is no possibility to align output clock to the 2 inoput clocks ?
    Even adding specific timing delay (mindelay/maxdelay/), global position, ... or something else in timequest sdc.
    Regards.
    FPGA is not the same as ASIC, so You'll have to deal with it and its rules.
    I remeber you that this is an ASIC PROTOTYPING so i cannot do what i want ...
    I need to make working the ASIC design in the FPGA without changing the VHDL ... as much as possible ...
    Why do You need to generate clocks? Clock generation can be achieved only using PLL, otherwise use clock enables.
    A precision. CLK1 and CLK2 are not direct INPUT pads of the FPGA !!!
    They are internal (generated) clocks ...
    So, how can i use the pll .???? i don't see.
    PLLs are able to switch clocks, so I believe there's a hardcore for such thing.
    Is is align to rising edge.
    I don't see how to add a gate ... how to be sure that clocks, in fact rising edge, are aligned ????
    A simple quartus example with a clock muxes, some FF clocked onto CLK1, others onto CLK2, and others onto clk_switch is welcome ...
    What does align refers to ? syn to rising or falling?
    There is a megafunction called altclkctrl to implent clk mux. It is a hard ip. Or you can add some logic to align it with the clock. Basically just use a AND gate and flops will do. You can find it in internet.
