15 years agoHow to align an output clock mux to 2 inputs clocks
Hi, I'm in charge of prototyping an ASIC into an FPGA altera Stratix3sl200. My problem is coming from the usage of clocks muxes inside ASIC :mad: Basically, they use a simple 2 inputs...
14 years agoI've made a small example which might fulfill your req's,
the idea is that your internally generated clocks (e.g 100MHz & 66Mhz) are replaced with clocks generated by a pll, 100 & 66 MHz, both pll outputs also go to clk_mux - altera megawizard ALTCLKCTRL module, which works as the clock mux, and both pll outputs go to "stratixiii_clkena" clock buff to compensate multiplexing delay [in case quartus is not smart enough to insert the buffs itself]; in the example cnt_100, cnt_66 mimics modules working with 100 and 66 clocks, cnt_sw works with 'switchable' clock;
module clk_switch
( input ext_clk, switch,
output reg cnt_100, cnt_66, cnt_sw
wire c100, c66;
wire sys_clk100, sys_clk66, sys_clk_sw;
pll pll_i
( .inclk0(ext_clk), .c0(c100), .c1(c66) );
stratixiii_clkena buff100
( .ena(1'b1), .enaout(),
.inclk(c100), .outclk(sys_clk100) );
stratixiii_clkena buff66
.inclk(c66), .outclk(sys_clk66) );
clk_mux clock_mux
( .clkselect(switch), .inclk0x(c100), .inclk1x(c66),
.outclk(sys_clk_sw) );
always @(posedge sys_clk100)
cnt_100 <= cnt_100 + 1'b1;
always @(posedge sys_clk66)
cnt_66 <= cnt_66 + 1'b1;
always @(posedge sys_clk_sw)
cnt_sw <= cnt_sw + 1'b1;
endmodule ---- have fun j_andr
