15 years agoHow to align an output clock mux to 2 inputs clocks
Hi, I'm in charge of prototyping an ASIC into an FPGA altera Stratix3sl200. My problem is coming from the usage of clocks muxes inside ASIC :mad: Basically, they use a simple 2 inputs...
15 years agoI struggle with that since 10 years :)
So, you confirm that there is no possibility to align output clock to the 2 inoput clocks ? Even adding specific timing delay (mindelay/maxdelay/), global position, ... or something else in timequest sdc. Regards.
