15 years agoHow to align an output clock mux to 2 inputs clocks
Hi, I'm in charge of prototyping an ASIC into an FPGA altera Stratix3sl200. My problem is coming from the usage of clocks muxes inside ASIC :mad: Basically, they use a simple 2 inputs...
15 years agoWhy do You need to generate clocks? Clock generation can be achieved only using PLL, otherwise use clock enables.
