Frequency divider with clk en.
I want to make a frequency divider (50 Mhz to any value, 560khz ), I am working with a counter like a freq. divider but there is a warning in Quartus II:
Warning: Found 1 node(s) in clock paths which may be acting as ripple and/or gated clocks -- node(s) analyzed as buffer(s) resulting in clock skew I read that using a CLK EN is the best way to make a freq. divider, but a I don't know nothing about it, DO YOU HAVE INFORMATION OR EXAMPLES ABOUT? HELP ME PLEASE13 Replies
Thanks !!!!!!!!!
It was the solution sharkybba, cordic with clock enable ...... Thanks to all for your help..... - Altera_Forum
Are you trying to clock the cordic block using the clk_en_568k signal by any chance? What you need to do is clock the cordic block from your 50MHz clock, and supply clk_en_568k to the cordic block as a clock enable signal. If the cordic block doesn't have a clock enable you'll have to modify it to add one.
Ok, if I compile only this code there is no problem, the problem is when I connect this freq divider with the cordic block (I am working with schematic diagram). Each block, cordic and freq divider, works fine individually.
Thanks. - Altera_Forum
I don't get this warning when synthesizing the above code with Quartus and also don't see a reason for it. I guess, you have additional code or specific assignments causing the warning.
FvM,
I was working with your code but I get the same warning. What a I want to do is a subsystem with a 560kHz clock output and a 18 bits output changing the value with the 560kHz freq too. This subsystem is connected to a cordic block, the 18 bits output is the angle for cordic and the 560kHz output is the work freq of cordic block. --- Quote Start --- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_unsigned.all; entity CE_div is Port ( clk: in std_logic; angle_out: buffer std_logic_vector(17 downto 0):="000000000000000000"; clk_en_568k: buffer std_logic ); end CE_div; architecture behav of CE_div is signal counter: integer range 1 to 88; begin process (clk) begin if rising_edge(clk) then --the convenient short cut -- 50 MHz Fast action if counter=2 then counter<=1; clk_en_568k <= '1'; else counter<=counter + 1; clk_en_568k <= '0'; end if; if clk_en_568k = '1' then -- 566k Slow action angle_out <= angle_out + "000000010000000101"; if (angle_out="011001001000011111" or angle_out>"011001001000011111" )then angle_out<="000000000000000000"; end if; end if; end if; end process; end; --- Quote End --- The warnings are: - Warning: Found 1 node(s) in clock paths which may be acting as ripple and/or gated clocks -- node(s) analyzed as buffer(s) resulting in clock skew - Warning: Circuit may not operate. Detected 5 non-operational path(s) clocked by clock "clk" with clock skew larger than data delay. See Compilation Report for details. Thanks for your answers... - Altera_Forum
That's the said clock enable method as a complete process block
I guess, that you had something likeprocess (clk) begin if rising_edge(clk) then --the convenient short cut -- 50 MHz Fast action if counter=88 then counter<=1; clk_en_568k = '1'; else counter<=counter + 1; clk_en_568k = '0'; end if; if clk_en_568k = '1' then -- 566k Slow action end if; end if; end;
before. That's what the synthesis tool was actually complaining about. Cause the freq_div, the ripple clock is delayed to clk, you have problems to process signals from the 50 MHz domain in the 568 kHz domain. They are changing state exactly at the clock edge, violating setup and hold times.if (freq_div'event and freq_div='1') then - Altera_Forum
Looks OK.
The other suggestion (What sharkybaba suggested) is to generate a clock enable rather than a clock. For example use your counter to generate a pulse that is high for 1 clock and low for 88. i.e. a pulse generator rather a clock generator. In the logic you need to be clocked at the slow clock, use something like process(clk) begin if (clk'event and clk='1') then if (clk_en = '1') then -- what ever you want -- clk en is the output pulse from your divider end if; end if; end process; In effect everything is still clocked from the 50MHz clock but you have generated a clock enable - Altera_Forum
vernmid, Here is the code:
process(clk) begin if (clk'event and clk='1') then counter<=counter + 1; if counter=44 then freq_div<=not(freq_div); counter<=1; end if; end if; end process; I was reading that this is not the best way for a freq divider; All suggestions are about PLL and clk enable method, maybe clk enable is the easiest way.....but I don't have information about it, thanks. - Altera_Forum
Chema,
My apologies, I misread your post! You will not be able to use a PLL to divide 50MHz to 560KHz. Stick with the counter as suggested (CLocked from your 50MHz). Count 0 to 43 then make an output low, count 0 to 44 then make the output high etc etc. Gives a slightly uneven Mark/Space ratio but this probable isn't an issue for you. Once again, sorry for the duff steer - Altera_Forum
sharkybaba,
Yes, I'm using the output of a register like a clk. How can I generate a signal every 89 ? Where the 50Mhz clk is connected ? Thanks a lot.
