18 years agoFrequency divider with clk en.
I want to make a frequency divider (50 Mhz to any value, 560khz ), I am working with a counter like a freq. divider but there is a warning in Quartus II: Warning: Found 1 node(s) in clock pat...
18 years agoLooks OK.
The other suggestion (What sharkybaba suggested) is to generate a clock enable rather than a clock. For example use your counter to generate a pulse that is high for 1 clock and low for 88. i.e. a pulse generator rather a clock generator. In the logic you need to be clocked at the slow clock, use something like process(clk) begin if (clk'event and clk='1') then if (clk_en = '1') then -- what ever you want -- clk en is the output pulse from your divider end if; end if; end process; In effect everything is still clocked from the 50MHz clock but you have generated a clock enable
