18 years agoFrequency divider with clk en.
I want to make a frequency divider (50 Mhz to any value, 560khz ), I am working with a counter like a freq. divider but there is a warning in Quartus II: Warning: Found 1 node(s) in clock pat...
18 years agoFvM,
I was working with your code but I get the same warning. What a I want to do is a subsystem with a 560kHz clock output and a 18 bits output changing the value with the 560kHz freq too. This subsystem is connected to a cordic block, the 18 bits output is the angle for cordic and the 560kHz output is the work freq of cordic block. --- Quote Start --- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_unsigned.all; entity CE_div is Port ( clk: in std_logic; angle_out: buffer std_logic_vector(17 downto 0):="000000000000000000"; clk_en_568k: buffer std_logic ); end CE_div; architecture behav of CE_div is signal counter: integer range 1 to 88; begin process (clk) begin if rising_edge(clk) then --the convenient short cut -- 50 MHz Fast action if counter=2 then counter<=1; clk_en_568k <= '1'; else counter<=counter + 1; clk_en_568k <= '0'; end if; if clk_en_568k = '1' then -- 566k Slow action angle_out <= angle_out + "000000010000000101"; if (angle_out="011001001000011111" or angle_out>"011001001000011111" )then angle_out<="000000000000000000"; end if; end if; end if; end process; end; --- Quote End --- The warnings are: - Warning: Found 1 node(s) in clock paths which may be acting as ripple and/or gated clocks -- node(s) analyzed as buffer(s) resulting in clock skew - Warning: Circuit may not operate. Detected 5 non-operational path(s) clocked by clock "clk" with clock skew larger than data delay. See Compilation Report for details. Thanks for your answers...
