18 years agoFrequency divider with clk en.
I want to make a frequency divider (50 Mhz to any value, 560khz ), I am working with a counter like a freq. divider but there is a warning in Quartus II: Warning: Found 1 node(s) in clock pat...
18 years agoThat's the said clock enable method as a complete process block
process (clk)
begin
if rising_edge(clk) then --the convenient short cut
-- 50 MHz Fast action
if counter=88 then
counter<=1;
clk_en_568k = '1';
else
counter<=counter + 1;
clk_en_568k = '0';
end if;
if clk_en_568k = '1' then
-- 566k Slow action
end if;
end if;
end; I guess, that you had something like if (freq_div'event and freq_div='1') then before. That's what the synthesis tool was actually complaining about. Cause the freq_div, the ripple clock is delayed to clk, you have problems to process signals from the 50 MHz domain in the 568 kHz domain. They are changing state exactly at the clock edge, violating setup and hold times.
