18 years agoFrequency divider with clk en.
I want to make a frequency divider (50 Mhz to any value, 560khz ), I am working with a counter like a freq. divider but there is a warning in Quartus II: Warning: Found 1 node(s) in clock pat...
18 years agoOk, if I compile only this code there is no problem, the problem is when I connect this freq divider with the cordic block (I am working with schematic diagram). Each block, cordic and freq divider, works fine individually.
