18 years agoFrequency divider with clk en.
I want to make a frequency divider (50 Mhz to any value, 560khz ), I am working with a counter like a freq. divider but there is a warning in Quartus II: Warning: Found 1 node(s) in clock pat...
18 years agoAre you trying to clock the cordic block using the clk_en_568k signal by any chance? What you need to do is clock the cordic block from your 50MHz clock, and supply clk_en_568k to the cordic block as a clock enable signal. If the cordic block doesn't have a clock enable you'll have to modify it to add one.
