17 years ago
FPGA Configuration using CPLD!
Hi all,
I have a question need your precious comments.
As I create my pcb with a Arria and MAXII. I planned to use Paralle Flash Loader in CPLD to configurate Arria.
After following AN386, I successfully download and write FPGA image to a CFI flash.
I use NIOSII IDE to programming and NIOSII command shell to read back. The data existed in flash.
After power cycle, the CPLD should start to move data from flash to FPGA but it's not working.
The input clock to PFL is 27MHz as attached qar.
I measure the address pin, there's 2 high level during flash OE period :confused:.
I wonder any one ever using this function and provide me your experience on that.
Thank you!
BRs,
Johnson
