17 years agoFPGA Configuration using CPLD!
Hi all, I have a question need your precious comments. As I create my pcb with a Arria and MAXII. I planned to use Paralle Flash Loader in CPLD to configurate Arria. After following AN3...
17 years agoHi Johnson,
The S29GLxxxP needs reset before starting access, and time from power-on or reset to 1st access is longer than previous model. I recommend you to make sure that reset signal is connected to the S29GLxxxp and put a counter in the MAX II so that PFL delays first access. Thanks!
