11 years agofir filter for fsk demodulator
i've realized an i_q demodulator for fsk message. The frequencies for the 0 and for the 1 are spaced 400Hz; the baud rate is up 200baud. The frequencies are in the audio range (for example F0=4050Hz and F1=4450Hz). That kind of demodulator needs two Low Pass filter for the i and q components. The problem is that in order to obtain an attenuation > 3dB @ 200Hz and >40db @ 400Hz the order of filter implemented is too high (now it is 1000) and the used resources overcome the max allowable by my FPGA (i.e. Memory Bits > 400.000). Is there any way or another kind of filter that could help me? Any others ideas? Thanks a lot.... My FPGA is cyclone ep4ce6
