11 years ago --- Quote Start --- in this way the parameters to pass to filter after the decimator is: Fs=50KHz; Fcut=100Hz Fstop=400Hz is it right? Can i use the FIR compiler 2? --- Quote End --- No... Fs is 200KHz Fcutoff ...etc use same filter I gave you (cuts at 200Hz and achieves -40dB at 6300Hz. you can use fir compiler. The output will be decimated to 50Ksps on same system clock of 200Khz (as rate of valid out will indicate)
