11 years agoif you model two frequencies in Matalb, you can see how to convert them to two levels:
f1 = exp(j*2*pi*(0:1023)*.1); f2 = exp(j*2*pi*(0:1023)*-.1); f=[f1 f2]; %two symbols plot(diff(unwrap(angle(f))),'.-') the angle is that of I/Q stream. diff is easy (current sample - next sample). the unwrap and angle are a bit tricky and is usually done in software but you can do it in vhdl by indirect methods. see: http://www.dspguru.com/dsp/tricks/fixed-point-atan2-with-self-normalization (http://www.dspguru.com/dsp/tricks/fixed-point-atan2-with-self-normalization)
