11 years agoi try this solution simulating it in simulink but it doesn't work
https://www.alteraforum.com/forum/attachment.php?attachmentid=9140 it works if i put a fir filter after a decimator with FS=50K, Fcut=100 and Fstop=400 but it has 500 taps in order to work correctly... One last thing that i ommitted: i need to obtain not real demodulation (0 and 1) but also the magnitude of output signal to understand if my input signal is @ full dynamic or not.... Could you check my design and eventually make your corrections? Thanks i've applied your advise of previous post and it works!!! Great!!!
