FIFO Interface
The fifo interface (http://www.ece.utexas.edu/~desimone/fifo_interface/) component interfaces a FIFO megafunction to the Avalon bus so the master can read or write it like a peripheral. It's pretty simple, really.
This is one of those peripherals that makes no sense whatsoever for a normal microcontroller, because there are too many fundamental variables (how wide? how deep?). The main site (http://www.ece.utexas.edu/~desimone/fifo_interface/) has all the documentation, or if you don't believe in documentation, you could just go ahead and download the component (http://www.ece.utexas.edu/~desimone/fifo_interface/download.html). This component is released as free software under the GNU Lesser General Public License. Since it is something I'm doing for fun, there is no guarantee of support. Of course, since it's open source, you're free to dive in and mess with your copy all you want. Feel free to identify bugs, suggest improvements, even send patches. There is a support topic on this forum, or you can try to contact me via email. Be advised that I'm not constantly in my office, so email replies may take up to a day or two (or longer, if I'm on travel). Have fun! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif13 Replies
--- Quote Start --- originally posted by larsen@Dec 1 2005, 08:20 AM this is what i have downloaded sep 08 2005regards
henning
sorry this seems not to work. error message is:
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
the total filespace required to upload all the attached files is greater than your per post or global limit. please reduce the number of attachments or the size of the attachments. --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=11291)</div> [/b] --- Quote End --- Can someone with the updated PTF file post it? Also I was wondering, why does this interface have a maximum fifo width of 32 bits? The Altera wizard allows you to specify much wider fifos... EDIT: Larsen sent me Jesse's PTF file. Hopefully this link stays up for a while.
this is what I have downloaded Sep 08 2005
regards henning Sorry This seems not to work. Error message is: <div class='quotetop'>QUOTE </div> --- Quote Start --- The total filespace required to upload all the attached files is greater than your per post or global limit. Please reduce the number of attachments or the size of the attachments.[/b] --- Quote End --- - Altera_Forum
--- Quote Start --- originally posted by james@Sep 8 2005, 03:04 PM blocking mode doesn't work. i've attached a fix (a new class.ptf file).the problem is that when blocking mode is specified, you have to set the read_wait_states and write_wait_states in the sbi to "peripheral_controlled" for avalon to honor the waitrequest signal.
to deploy the fix, just overwrite the original class.ptf with this new file, run sopc builder, and double-click on all existing instantiations of the component to get the wizard_finish portion of the class.ptf to run, and then regenerate.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=9653)
--- quote end ---
--- Quote End --- I can't download the fix. The file seems not to exist. Can anyone help? I Need the blocking mode.... Bye and thanks Marco
Blocking mode doesn't work. I've attached a fix (a new class.ptf file).
The problem is that when blocking mode is specified, you have to set the Read_Wait_States and Write_Wait_States in the SBI to "peripheral_controlled" for Avalon to honor the waitrequest signal. To deploy the fix, just overwrite the original class.ptf with this new file, run SOPC Builder, and double-click on all existing instantiations of the component to get the wizard_finish portion of the class.ptf to run, and then regenerate. - Altera_Forum
Hello
I had the same problem. But the solution is to use the full bit as MSB [full, usedw[] ]. This word give the exact number of words in the fifo. Thanks to Mike his fifo-Interface works great. Joerg [email protected] - Altera_Forum
Sorry for the late reply; I don't check this board as much as I should. In the future, please email me with your questions; I check that at least every business day.
--- Quote Start --- originally posted by muffec@Mar 30 2005, 06:41 AM i'm trying the fifo interface but for a fifo of 512 words of 32 bits, the fifo has a usew of 9 bits and the fifo interface has a usew of 10 bits. why? and how can i solve that? --- Quote End --- I have a guess what's going on. 512 in hex is 0x200, which requires 10 bits to represent. The FIFO Interface assumes that you can use all memory in the FIFO, not one-less-than-all, so the usedw[] bus would need to be one more bit wider than the memory's address bus would be. The solution, if the FIFO stops one element short of full like that, is to set the high bit of usedw[] into the FIFO interface to 0, and if you use the words-free stuff in the FIFO interface, to check the box for "FIFO uses 1 less than all words" (or something to that effect) in the configuration window. --- Quote Start --- originally posted by muffec@Mar 30 2005, 06:41 AM i'm also trying to write on the fifo interface and i can't. would you have a demo of using the fifo interface with a dma on nios ide? --- Quote End --- I'm not sure what that bug is exactly, but I encountered one like it, although it involved a DMA peripheral talking to something other than a FIFO interface. If I connected a DMA master to only one slave, and that slave had only one register (i.e. no address bus), the DMA would execute but the data wouldn't be written to the port. The problem was that the Avalon bus master arbitrator for the DMA would send an address of 0 to the slave arbitrator (thinking the address is unused), but the slave was expecting the real address. I don't know if that bug still exists, or if it applies to the FIFO interface (which does have an address bus). The workaround was to connect the master to slaves which have addresses above and below the slave you're actually trying to use; I used my ROM (which is at 0) and my RAM (which is at the highest address). I don't have code that uses the FIFO interface with the HAL DMA interface in the Nios IDE; I programmed the DMA registers directly. The main rules are to set the DMA address for the FIFO end of the transfer to the base address of the FIFO interface, set the flag for the proper transfer size, and to set the flag that tells the DMA not to increment that address. - Altera_Forum
I'm trying the fifo interface but for a fifo of 512 words of 32 bits, the fifo has a usew of 9 bits and the fifo interface has a usew of 10 bits. Why? And how can i solve that?
I'm also trying to write on the fifo interface and I can't. Would you have a demo of using the fifo interface with a DMA on nios ide? Muffec [email protected] - Altera_Forum
Oi. I fixed that over here, but forgot to upload it. All better now.
Version 0.1.1 attached for your convenience. - Altera_Forum
Mike,
Having done some fine-reading on the header file "arlut_fifo_interface_regs.h" and its macro's followed by a quick simulation I think I finally can contribute constructively to your fifo interface. The REGISTER_BIT macro should read
The original one never takes account of the bitNum parameter (end of second line). regards henning#define REGISTER_BIT(regName, bitName, bitNum) ARLUT_FIFO_INTERFACE_##regName##_##bitName##_OFST = bitNum, ARLUT_FIFO_INTERFACE_##regName##_##bitName##_MSK = (1 << ARLUT_FIFO_INTERFACE_##regName##_##bitName##_OFST) - Altera_Forum
--- Quote Start --- originally posted by larsen+oct 13 2004, 05:33 am--><div class='quotetop'>quote (larsen @ oct 13 2004, 05:33 am)</div>--- quote start ---
in the software part you have some pretty fancy macros. would it be posible for you to post some code snippets on how they are intended to be used.[/b]
--- quote end ---
the register_bit macro is for use in that header only (to save me typing, clutter, and potential errors); it's# undef'd on the way out.
that said, the other macros defined are all named the standard altera way, e.g. iord_arlut_fifo_interface_regname(base) reads from a register, and iowr_arlut_fifo_interface_regname(base, value) writes to a register. for the bits in the status register, arlut_fifo_interface_status_bitname_ofst is the bit's offset, and arlut_fifo_interface_status_bitname_msk is the bit mask. for control register bits, change status to control.
<!--quotebegin-larsen@Oct 13 2004, 05:33 AM interrupt use would also be interesting to see. --- Quote End --- I haven't written any interrupt-using code for a couple reasons:[list][*] My current application is so memory-constrained that I don't have interrupts (everything is polled), so I can't justify writing interrupt handler code I'm not using, [*] Assumptions would need to be made that would likely not be valid (for example, I could write a HAL character-device driver, but that can't work when the FIFO width is greater than 8 bits without extraneous word splitting and merging), [*] The user will be able to write much better (read: more specialized to their application) code than I can, and [*] I'm still learning SOPC Builder's and HAL's way of doing things. [/list]If you need a starting point for basic uses, I would recommend looking at the Altera Nios UART driver for a starting point. Anything I wrote would look a lot like that. If you want more specific help, please contact me by email.
