22 years agoFIFO Interface
The fifo interface (http://www.ece.utexas.edu/~desimone/fifo_interface/) component interfaces a FIFO megafunction to the Avalon bus so the master can read or write it like a peripheral. It's pre...
20 years ago --- Quote Start --- originally posted by larsen@Dec 1 2005, 08:20 AM this is what i have downloaded sep 08 2005
regards
henning
sorry this seems not to work. error message is:
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
the total filespace required to upload all the attached files is greater than your per post or global limit. please reduce the number of attachments or the size of the attachments. --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=11291)</div> [/b] --- Quote End --- Can someone with the updated PTF file post it? Also I was wondering, why does this interface have a maximum fifo width of 32 bits? The Altera wizard allows you to specify much wider fifos... EDIT: Larsen sent me Jesse's PTF file. Hopefully this link stays up for a while.
