22 years agoFIFO Interface
The fifo interface (http://www.ece.utexas.edu/~desimone/fifo_interface/) component interfaces a FIFO megafunction to the Avalon bus so the master can read or write it like a peripheral. It's pre...
20 years ago --- Quote Start --- originally posted by james@Sep 8 2005, 03:04 PM blocking mode doesn't work. i've attached a fix (a new class.ptf file).
the problem is that when blocking mode is specified, you have to set the read_wait_states and write_wait_states in the sbi to "peripheral_controlled" for avalon to honor the waitrequest signal.
to deploy the fix, just overwrite the original class.ptf with this new file, run sopc builder, and double-click on all existing instantiations of the component to get the wizard_finish portion of the class.ptf to run, and then regenerate.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=9653)
--- quote end ---
--- Quote End --- I can't download the fix. The file seems not to exist. Can anyone help? I Need the blocking mode.... Bye and thanks Marco
