22 years agoFIFO Interface
The fifo interface (http://www.ece.utexas.edu/~desimone/fifo_interface/) component interfaces a FIFO megafunction to the Avalon bus so the master can read or write it like a peripheral. It's pre...
22 years ago --- Quote Start --- originally posted by larsen+oct 13 2004, 05:33 am--><div class='quotetop'>quote (larsen @ oct 13 2004, 05:33 am)</div>
--- quote start ---
in the software part you have some pretty fancy macros. would it be posible for you to post some code snippets on how they are intended to be used.[/b]
--- quote end ---
the register_bit macro is for use in that header only (to save me typing, clutter, and potential errors); it's# undef'd on the way out.
that said, the other macros defined are all named the standard altera way, e.g. iord_arlut_fifo_interface_regname(base) reads from a register, and iowr_arlut_fifo_interface_regname(base, value) writes to a register. for the bits in the status register, arlut_fifo_interface_status_bitname_ofst is the bit's offset, and arlut_fifo_interface_status_bitname_msk is the bit mask. for control register bits, change status to control.
<!--quotebegin-larsen@Oct 13 2004, 05:33 AM interrupt use would also be interesting to see. --- Quote End --- I haven't written any interrupt-using code for a couple reasons:[list][*] My current application is so memory-constrained that I don't have interrupts (everything is polled), so I can't justify writing interrupt handler code I'm not using, [*] Assumptions would need to be made that would likely not be valid (for example, I could write a HAL character-device driver, but that can't work when the FIFO width is greater than 8 bits without extraneous word splitting and merging), [*] The user will be able to write much better (read: more specialized to their application) code than I can, and [*] I'm still learning SOPC Builder's and HAL's way of doing things. [/list]If you need a starting point for basic uses, I would recommend looking at the Altera Nios UART driver for a starting point. Anything I wrote would look a lot like that. If you want more specific help, please contact me by email.
