14 years ago
Error in signal assignment with VHDL
I'm trying to create a simple register connected to a 8-width bidirectional bus. But when I read a value from this bus and write it back, some of these bits receive don't care value, while others are ok. I didn't understand that since I don't deal with these bits individually. Someone could help?
Below is the code:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
use IEEE.std_logic_arith.all;
entity reg is
    generic(
        MAX_COUNT: in natural := 8);
    port(data: inout std_logic_vector(MAX_COUNT-1 downto 0);
         incr,decr,lr,erd: in bit;
         clk: in std_logic);
end entity;
architecture behavioral of reg is
signal out_r: std_logic_vector(MAX_COUNT-1 downto 0);
begin
    process(clk)
    variable var: std_logic_vector(MAX_COUNT-1 downto 0);
    begin
        if rising_edge(clk) then
            if lr = '1' then
                var := data;
            end if;
            if incr = '1' then
                var := var+1;
            end if;
            if decr = '1' then
                var := var-1;
            end if;
            out_r <= var;
        end if;
    end process;
    process(clk,erd)
    begin
         if erd = '1' then
           data <= out_r;
         else
           data <= (others => 'Z');
         end if;
       end if;
    end process;
end architecture;
... and the image of the error in ModelSim:
&&&dl.dropbox.com/u/288645/erro_view.PNG&&&
Clearly we can see that some bits of the bus 'data' are don't care while others seem to have the correct value.
lr -> means load R
erd -> means enable R to bus
The others are easier. Thanks for the attention!
    I know that. It's not going to be implemented on hardware (maybe in the future). The project is an assynchronous microprocessor only for learning purposes. Anyway, thank you all people.
    I hope that your INOUT signal is going to the pins of the FPGA. Then there are no tri-state drivers inside the FPGA internal logic. Only the I/O's have tri-state drivers.
    This is a small part of a microprocessor, then I have no choice.
    yes, you could do that - but why do you need an inout bus at all? why cant you have separate data_in and data_out?
    Ok. So the solution is force just one value (against HiZ). Thus, in this case, when I put erd = '1', I need to have data = 'ZZZZZZZZ' in the testbench. Is that right?
    First things first. A 'X' is not a don't care for std_logic signals. A don't care is '-'.
    What you see is two active bus drivers (one is your testbench and the other your design) are active at the same time and driving different values against each other.
    Ok to explain what happens lets go through your simulation step by step:
    time = 0 ns (start of simulation)
    your testbench sets
    incr = '1'
    decr = '0'
    lr = '0'
    erd = '0'
    data = 185
    your logic does
    out_r = "UUUUUUUU" (no assignment at declaration)
    data = "UUUUUUUU" (no assignment at declaration) and the testbench drives 185 here is a conflict and you get "XXXXXXXX"
    time = 5 ns (rising clock edge)
    your logic does
    out_r = "UUUUUUUU" + 1 = "XXXXXXXX"
    data = "ZZZZZZZZ" therefore the testbench driver wins and you see 185
    time = 10 ns (testbench changes)
    your testbench sets
    incr = '0'
    decr = '1'
    lr = '1'
    erd = '0'
    data = 114
    time = 15 ns (rising clock edge)
    your logic does
    out_r = 114 - 1 = 113
    data = "ZZZZZZZZ" therefore the testbench driver wins and you see 114
    time = 20 ns (testbench changes)
    your testbench sets
    incr = '0'
    decr = '0'
    lr = '1'
    erd = '1'
    data = 101
    time = 25 ns (rising clock edge)
    your logic does
    out_r = 101
    data = previous out_r = 113 ("0111 0001") driving against 101 ("0110 0101") resulting in ("011X 0X01")
    and so on.
