14 years agoError in signal assignment with VHDL
I'm trying to create a simple register connected to a 8-width bidirectional bus. But when I read a value from this bus and write it back, some of these bits receive don't care value, while others are...
14 years agoFirst things first. A 'X' is not a don't care for std_logic signals. A don't care is '-'.
What you see is two active bus drivers (one is your testbench and the other your design) are active at the same time and driving different values against each other. Ok to explain what happens lets go through your simulation step by step: time = 0 ns (start of simulation) your testbench sets incr = '1' decr = '0' lr = '0' erd = '0' data = 185 your logic does out_r = "UUUUUUUU" (no assignment at declaration) data = "UUUUUUUU" (no assignment at declaration) and the testbench drives 185 here is a conflict and you get "XXXXXXXX" time = 5 ns (rising clock edge) your logic does out_r = "UUUUUUUU" + 1 = "XXXXXXXX" data = "ZZZZZZZZ" therefore the testbench driver wins and you see 185 time = 10 ns (testbench changes) your testbench sets incr = '0' decr = '1' lr = '1' erd = '0' data = 114 time = 15 ns (rising clock edge) your logic does out_r = 114 - 1 = 113 data = "ZZZZZZZZ" therefore the testbench driver wins and you see 114 time = 20 ns (testbench changes) your testbench sets incr = '0' decr = '0' lr = '1' erd = '1' data = 101 time = 25 ns (rising clock edge) your logic does out_r = 101 data = previous out_r = 113 ("0111 0001") driving against 101 ("0110 0101") resulting in ("011X 0X01") and so on.
