Sameer-sahu
2 months agoError (209014): CONF_DONE pin failed to go high in device 1.
I want to flash a simple led blink code bitstream file in Cyclone V E Dev kit using USB blaster. When I am trying to flash using USB blaster I am getting below error: Error (209014): CONF_DONE pin f...
FakhrulA_altera
1 month ago
Hi Sameer,
Thank you for the update.
From the screenshot, the device is detected in JTAG, so the USB-Blaster connection looks OK. The error at around 32% usually means the FPGA configuration did not complete, and CONF_DONE did not go high.
Please try the following next:
- Use the built-in USB-Blaster II on the Cyclone V E Development Kit.
- Confirm the .sof file is generated for the exact FPGA device on the board, for example 5CEFA7F31.
- Try programming one of the example .sof files from the Cyclone V E Development Kit design package.
- Keep the board DIP switch setting at the default/factory setting as listed in the development kit user guide.
If the example .sof file also fails with the same error, please share the Quartus version used and a clear photo of the board DIP switch settings.
Fakhrul
Sameer-sahu
1 month agoHi FakhrulA_altera ,
Could you please suggest any feedback based on my previous replay. So that I can debug the Issue quickly.
