Error (209014): CONF_DONE pin failed to go high in device 1.
Hi FvM ,
I have tried to use built-in USB Blaster then also I got the same error. When I tried to flash the .sof bitstream file at that time D11 led present in the board was glowing. When the failed message pop up then that led turn of. Below are my DPI switch setting:
SW1 = keep factory/default MSEL setting
SW2-1 = OFF // MAX V CPLD 5M2210 System Controller in-chain
SW2-2 = ON // bypass HSMC port
SW2-3 = OFF // fan disabled
SW2-4 = OFF // reserved
SW4-1 = ON // select programmable oscillator clock
SW4-2 = OFF // enable on-board oscillator
SW4-3 = OFF // load factory design from flash at power-up
SW4-4 = OFF // embedded USB-Blaster II does not send FACTORY command at power-up. Can you please suggest do I miss any steps or share me some example code along with details procedure then it will fast the process instead of open forum. My mail id is [email protected].
