16 years agoDon't optimize away method issue need your help
Hi all:
I am using EPM7512AETC144-12 device. There many trigger signals need to be delayed in my design. For the limitation of the resource, i use gate delay to archive this function. I found there are 512 reigisters not be used after compiling and all 512 macrocells being used up. So i think if can i use these registers to add more delay time on my trigger signals? And i added a latch before trigger delayed, just like the attached file, but i found there are some warning information, and the latch was optimized away. Below is the warning: "Warning: LATCH primitive "inst37" is permanently enabled"7 Replies
Hi FvM,
Thanks for your kindly reply! I am unconnectly these days, and sorry for the delay of this reply. I attach my project, and i found "ignore lcell" setting is not activity for my project or CPLD devices. When i set off or auto, the result is same. I found beow your reply in another thread: "However, regarding achieved delay, I don't see additional options to increase it, except for routing the signal in and out of I/O pins. You should also consider, that you don't necessarily increase the delay by using a slower speed grade. The specification is about maximum delay, these devices are designed as logic chips rather than delay lines." Do you mean that I don't need to trust the tpd report? If will these tpd information change after implemented into CPLD device? - Altera_Forum
Can you post a minimal design, where the gatedly block is instantiated and actually consumes macrocells? Or are you using additional global settings?
P.S.: I found that "Ignores LCELL buffers" must be set to "off". Because the synthesis attribute in gatedly doesn't work alone. Both have to be set. - Altera_Forum
Seems like you found a way to keep CPLD macro cells. I'll study the results later on.
Regarding registers, you should refer to the MAX7000 macro cell description in the datasheet. There's no dedicated latch available, just a DFF with a bypass path. So, if you don't need a synchronous register, it's simply bypassed. I don't see, how it could work as a delay element. - Altera_Forum
In fact, my quesiton is how to use the rest 512 registers resource?
And my terminal goal is to get the longest tpd value for each signal input CPLD. You know I just need more delay time for these input signals. - Altera_Forum
Hi FvM:
Thanks! But i run below code in my design, and can be implemented very well. And this code just is the block "Gatedly": ---------code start----------------- LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; library altera; use altera.altera_syn_attributes.all; ENTITY Gatedly IS generic( DELAY : positive :=9 ); PORT ( trig_in : in std_logic; trig_out : out std_logic ); END Gatedly; ARCHITECTURE arch OF Gatedly IS signal delay_line: std_logic_vector(DELAY-1 downto 0); attribute keep: boolean; attribute keep of delay_line: signal is true; BEGIN gen_delay: for i IN 1 TO DELAY-1 generate delay_line(i) <= delay_line(i-1); end generate; delay_line(0) <= trig_in; trig_out <= delay_line(DELAY-1); END arch; ------code end----------------- And i can get attached tpd values when change the "DELAY" value for each trigger signal. - Altera_Forum
--- Quote Start --- "Warning: LATCH primitive "inst37" is permanently enabled" --- Quote End --- Yes, the warning says just what you have written in your code. It's a warning, not an error. You didn't tell, what's in the "gatedl" block. But I guess, it's a logic cell delay chain, that is simply ignored by the compiler. Right? Did you read my post in your previous same-topic thread? The CPLD synthesis tool doesn't support "keeping" of redundant logic cells, even by synthesis attributes. - Altera_Forum
