16 years agoDon't optimize away method issue need your help
Hi all: I am using EPM7512AETC144-12 device. There many trigger signals need to be delayed in my design. For the limitation of the resource, i use gate delay to archive this function. I ...
16 years agoHi FvM:
Thanks! But i run below code in my design, and can be implemented very well. And this code just is the block "Gatedly": ---------code start----------------- LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; library altera; use altera.altera_syn_attributes.all; ENTITY Gatedly IS generic( DELAY : positive :=9 ); PORT ( trig_in : in std_logic; trig_out : out std_logic ); END Gatedly; ARCHITECTURE arch OF Gatedly IS signal delay_line: std_logic_vector(DELAY-1 downto 0); attribute keep: boolean; attribute keep of delay_line: signal is true; BEGIN gen_delay: for i IN 1 TO DELAY-1 generate delay_line(i) <= delay_line(i-1); end generate; delay_line(0) <= trig_in; trig_out <= delay_line(DELAY-1); END arch; ------code end----------------- And i can get attached tpd values when change the "DELAY" value for each trigger signal.
