Do you use LPMs for your LFSRs?
I want to implement an LFSR as a means of generating random numbers but I'm not sure whether to use an LPM or just code it in a process. I would be interested to hear how you choose to implement them and if possible, why? I considered using either LPM_SHIFTREG or altshift_taps but I'm not sure how suitable they are. Many thanks
Apologies for some confusion I caused about the two forms of lfsr. There are two equivalent types(Fibonacci and Galois). I was thinking only of Fibonacci type with taps feeding back onto first stage.
Thanks to all. I had made a stupid mistake, I had 'clock' in my process but I was actually using a different (reduced) clock in my simulation. Once I corrected that it worked perfectly. I have read up quite a lot on LFSRs so it was really bugging me!:rolleyes: Thanks again. This forum is invaluable.
--- Quote Start --- Thanks again Kaz. I can't quite see where I was going wrong
When I simulate this the output is always 1? --- Quote End --- This is a perfect implementation of 4-bits LFSR. If it stays at 1, check your reset signal. Good luck, Tonprocess(reset,clock) begin if reset = '1' then shift_reg <= "0001"; -- seed elsif rising_edge(clock) then shift_reg(1) <= shift_reg(0) XOR shift_reg(3); -- taps shift_reg(2) <= shift_reg(1); -- shift shift_reg(3) <= shift_reg(2); end if; output <= shift_reg; end process; - Altera_Forum
--- Quote Start --- It seems that the output sticks at whatever value I set the seed to be, i.e. a seed of 1111 resuts in a constant output of 15. --- Quote End --- The design is showing a perfect LFSR sequence of length 15 in simulation. I guess you missed to release the reset signal - or supplied no clock. --- Quote Start --- according to xilinx doc a 4 bit shift register should have taps at 3,4 --- Quote End --- This is a different form of the same sequence. - Altera_Forum
shift_reg(0) <= shift_reg(2) xor shift_reg(3); shift_reg(3 downto 1) <= shift_reg(2 downro 0); - Altera_Forum
Your feedback point should be stage 0 not stage 1
By using the simulator within Quartus, I just ran the simulator, expecting to see 'output' change value each clock cycle but it is a constant value of '1'. It seems that the output sticks at whatever value I set the seed to be, i.e. a seed of 1111 resuts in a constant output of 15.
It looks like a correct implementation of x^4 + x^3 + 1. How did you test it?
I changed the code to reflect a 4-bit LFSR that I know should step through all possible combinations, i.e. maximal length.
It still does not seem to work though.process(reset,clock) begin if reset = '1' then shift_reg <= "0001"; -- seed elsif rising_edge(clock) then shift_reg(1) <= shift_reg(0) XOR shift_reg(3); -- taps shift_reg(2) <= shift_reg(1); -- shift shift_reg(3) <= shift_reg(2); shift_reg(0) <= shift_reg(3); end if; output <= shift_reg; end process; - Altera_Forum
Probably your xor results in 1 always.
You need to use standard proven register lengths and taps. There is plenty of literature for various sizes and taps. e.g.one from xilinx: google xilinx LFSR also note your feedback point should be at one end rather than 2nd stage
