15 years ago
Dividing clock source - PLL
I was trying to reduce clock frequency of Cyclone II i Quartus form 50MHz to 5 Hz. I heard, this need to be done by megawizard, SoPC builder and then PLL. But the thing is, that I cannot smaller the frequency to less than 10MHz. I've searched many web pages to find the solution, and I'vo got no. Could anyone give me a simple step by step answer how to reduce the clock frequency, or just give some clues?
blasq
    24 bit counter will do. just do it in HDL yourself.
    The pulse generated wouldn't be 50%duty cycle.
    if you want 50%duty cycle use a bit of logic on your counter to set led high/low equally, high from 0 to 5,000,000-1 then low
    Ok, I got it. But how can I do such a big counter? I don't see arbitral-value counter in symbols or SoPC builder.
    thanks,
    blasq
    For led use a counter running from 0 to 10,000,000-1 and connect The counter msb to the led.
    Thanks for reply, @Tricky
    I don't see it clear. Let's suppose I have one LED pin out, and I want to supply it with 5Hz pulse. I create a PLL with enable input? And then, how to connect it?
    thanks for help,
    blasq
    5 Hz is much too slow for a PLL, and as you can see, the minimum output of a PLL is 10MHz.
    What you need to do is clock your 5Hz logic at 50MHz, and generate a clock enable that makes the circuit appear to run at 5Hz.
